Hi
von luiscifer00
aus: C5-L@yahoogroups.com
C5 FAULTS INFORMATION:
Switch off of the combined system while being driving
( radio,roadlights,inside lights, indicators board etc.).
This switch off lasts only for a few seconds, but during this period
all the above mentioned items are off. This is caused due to a reset
of the BSI and it has been produced in the Peugeot 307 which shares
this system.Apparently,the problem has been solved due to the
upgrading of the software in charge of the BSI. Using a version
above the 2.? (I do not remember exactly which) the problem ceases to
exist.
Automatic lights : they stop working from now and
then. Besides, the system is not sufficiently intelligent enough to
detect precisely the necessary light conditions to activate the
lights.Sometimes the lights keep switched on during day
light.However, this happens only on rare occasions.
Noise from thecentral air outlets everytime the car speeded or
braked. It sounded as if there was water waving. It was produced due
to the condensation of water in that place.
The solution was a modification in the draining system to prevent
water from keeping there. It consisted on replacing the channeling
tube for another one that did not produced this effect.
Lowering of the driver seat.
This was caused because when one gets into the car the handle that
controls the seat height is pressed accidentally.
The C5 service said the solution is the changing of handle in one of
the sides for the handle in the other one to invert the angle of the
handle and avoid it being pressed by mistake.This has resulted a poor
solution and the handle has to be pressed many more times to get it
down.
Unprogramming of some of the windows.When this happens the window
cannot be elevated automatically at once when we pressed the button.
The solution comes when we manage to elevate the window and after it
is totally closed the botton is kept pressed for a few seconds.
Flashing of the road lihgts due to a diminishing of the voltage
produced by the activation of the
suspension pump.The function of the pump is the introduction of
liquid in the system to elevate the suspension.The flashening can be
clearly noticed following these steps: in front of a wall with the
lights on , elevate the suspension. This flashening happens with
halogen lights,though it can also be appreciated in the inside lights.
The combustion gases from the vehicles in front of the car get
into the car through the aircon. This is very disgusting.I do not
know whether it happens in other cars.
The sensor temperature under certain conditions such as rain and high
humidity gave a mistaken lecture and on a rainy day the temperature
that appeared on display was increasing and it did not correspond to
the actual temperature which was 18ºC. degrees and the sensor
reflected around 40ºC .The C5 service replaced the sensor.The sensor
is found on the low part of the outside rear-view mirror .It looks
like a small botton.
Dialers in the indicators board.They move without control
for a few seconds. To check this: switch off the engine,stay
inside the car and you will observe that after you remove the key
being the doors closed, the radio and the lights off ...(all the
systems off). About few minutes after everything is off a"click" will
be
heard and the dialers will vibrate crazily for some seconds. This is
something normal. It occurs in every car with BSI.
Fuel comsumption reading (l/100Km) The display shows occasionally a
false reading :the fuel comsumption reading is 0.4 l/100Km for
example.The C5 service advices to reset it everytime the car is
refuelled. What an average, then!.
Blocking of door locking button. The inside button to lock the doors
(the one with a padlock drawn) stops working when the doors are
locked with this button (not with remote key) and without disactivate
it one of the back doors are open from inside .Then, if we press it
again , the doors will be locked but the button will not work again
till we use the remote key. This gives way to driving with the doors
unlocked because if the ignition key is on the remote key does not
work unless the ignition key is off . This is a general problem in
every C5.
..Fortsetzung
The numbers of the magazine "AUTO JOURNAL" in which the faults common
to the C5 model appear are: nº 591 April 4th 2002 and nº 589 March
7th 2002.
List of the main problems and date of manufacturing from which these
have been solved.
OUTWARD APPEARANCE:
_ Risk of water getting into the boot when opening it after rain. The
joint was modified in June 2001. (It is not correctly solved).
_ Break. Escape of liquid from the wind screen wiper in the back
glass when bending the car at a high speed . This happens because
there is no locking valve. Modified in July 2001.
_ Break. Failure in the electric system that opens the back window.
Modified in October 2001.
_ Break. Failure of watertightness in the back lights. Modified in
July 2001.
MECHANICS:
_ Motor 2.0 16V. Risk of bad functioning in the circuit of
recirculation of EGR gases due to disconection in the depression
tube. Modified in May 2001.
_ Motor 2.0 HDI. Bad functioning in the EGR circuit . Modified in May
2001.
_ Motor HPI. Unsteady functioning due to some failures in the
switchboard. Software modified in October 2001.
_ Motor HPI. Power decrease. Difficulty in the ignition due to the
unpriming of the injection pump. Solution: sustitution of the pump
when it fails.
_ Motor HDI (all). Power decrease due to the watertightness in the
injection pump produced by the rusting of a copper part. Replacement
of the old pump from September 2001.
_ Motor 2.0 HDI. Shakes since the car is started till the engine is
off. Failure in the motive flywheel. Solution still under study.
_ Motor 2.2 HDI. Risk of fuel wastage in the return circuit. New
joint from June 2001.
_ Motor 2.2 HDI. In some cars, failure in the particle filter control
due to an error in the electronic calculator. Solution: Reprogramming.
_ Motor 2.2 HDI. Risk of breaking of the camshaft chain ( as in the
same motor in the Peugeot 607 ), produced by a faulty chain strut .
Modified in April 2001.
_ Occasionally it is not possible to start the car due to failures in
the starting motor code. Modified in March 2001.
_ Gearbox. Occasionally it is not possible to use the parking
position. About 2500 cars affected. Modified in July 2001.
_ Suspension. Risk of failure of the auto adaptive driving after
great distance in kilometers due to problems of watertightness in the
management box. Modified in October 2001.
_ ABS. Risk of failure due to problems in the front SKF ball
bearings. Replaced by SNR ball bearings.
_ Tyres. Excessive wear in the back tyres. Cause still under study.
INTERIOR SPACE.
_ Locking device (door locking system). Bad functioning. Software
_ Front wind screen wiper. Alert light switched on without any reason
due to a failure in the electric supply. Repaired during the car
launching.
_ Multiple back noises. Possible causes: Friction of the filling fuel
tube with the cover in the tyre hollow. Unsteady fixings of the backs
of the back seats. Unsteady fixings of the jack.Failure in the design
of the shock absorber fixings.
Interessant - die Probleme haben wir alle hier schon beschrieben, und einige kenne ich aus eigener Erfahrung. Was haben wir uns da eigentlich für ein Fahrgerät gekauft?
Martin
Eine Beta-Version halt. Viel Vergnügen!
Hi
naja, zahlreiche Probleme konnte ja schon behoben werden.
Für einige gibt es einfach Abhilfe (z.B: Scheibenheber)
bleibt noch:
_Blocking of door locking button.
_Flashing of the road lihgts due to a diminishing of the voltage
produced by the activation of the suspension pump (halogen lights)
Der Begriff "Betatester" für die 2001 BJ. scheint hier vollkommen
zu stimmen, sieht man gearde was alles schief läuft
wenn die Software nicht stimmt.
Andrew
ACCM Helmut Bachmayer
so what, all these fault happen everywhere at the monent, you can even go for the star and be a tester for more money, but besides, normally I consider this side a german one, so please translate texts to be published into german, yours der bachmayer
