[XM] Adjust Centrifugal Regulator
Hello dears,
Once again I come for help from you regarding the direction of XM. The direction of my XM is soft all the time, so I went to the mechanic to check.
The mechanic opened the centrifugal valve to lubricate, then mounted and placed in the car.
The valve worked because diravi stiffened, now the problem is that this occurs even when the car is stopped. I need to hold tight direction, but the force diravi steer hard to the center.
My XM speedometer works only sometimes and the displayed speed seems to be wrong.
The mechanic said the problem may be related to the speedometer, specifically the cable connected to the automatic transmission.
What do you think about this?
Thanks!
