Der Diagbox-Software liegt die TLCDfix.exe bei. Damit werden Inhalte von *.xml Dateien geändert
This application removes all lines containing: <Door Name="TLCD_ASSISTANCE_CODE" Number="4"/> from all *.XML files in a folder (by default path is C:\AWRoot\dtrd\comm\XMLTLCD\, but you can specify the path to different location). This also creates a copy of the file, with the extension *.BAK.
Welches Problem löst das?
Ronald
