Folgende Mail habe ich soeben aus der engl. XM-Liste herausgefischt, das wären wohl richtige "Exoten"...?
--- In XM-L@yahoogroups.com, "Georgievski, Aleksandar" <Aleksandar.
Georgievski@o...> wrote:
>> I have also heard (a reputable Citroen dealer told me this some
>> 6-7 years ago) that there are indeed a dozen or so Maserati-engined
>> XMs produced in the early nineties, used as a quasi-prototype...
>> For PSA it is not unknown that such semi-prototype series were
>> used to test the design in real-life circumstances:
Yes, PSA does this quite often before the introduction of a new car or
a new engine. I have recently had access to some Xantia service info,
which lists a Xantia 2.5TD, and a 2.2HDI also with Activa suspension,
probably as tests for the XM series II and the C5 in the later case
(too bad the Activa suspension did not get carried over!). I have seen
a 2.1TD estate Xantia Activa myself - something that is not supposed
to exist. This one was sold in Switzerland to a long time Citroen
customer. These days I drive a Xantia 2.0HDI - although a fine car in
it's own right, it's no XM and I would trade it for a 2000 or 2001 XM
2.5TD in a nanosecond - it is also special being one of the first
made. It's steering and brakes are from the Peugeot 605, which gives
it a rather large steering radius (larger than the XMs!) but also top
notch brakes, rotors are about 20% larger than standard and pads
almost twice as large.
Z
Hi Christian,
das waeren wirklich Exoten. Gehoert habe ich allerdings noch nie davon.
Gruesse aus Luedenscheid
Stefan
ACCM Oliver Weiß
Mir sind diese Modelle zwar auch unbekannt, aber es gab immer wieder ungewöhnliche Prototypen. Manche kamen auch mal in private Hände, z.B. geisterte mal ein BX Coupe hier im forum rum.
Weitere Beispiele ungewöhnlicher Citroens:
CX Serie 2 mit V6 als XM Erprobungswagen
DS Coupe mit V6 als SM Erprobungswagen
C5 mit breiterer Spur und ca 10 cm längerer C-Säule, vermutlich C6 Erprobungswagen
Ein Activa Kombi oder der 2,2 HDi im Xantia paßt genauso in das Schema.
Nachtrag:
XM mit Maserati Motor, das paßt irgendwie nicht. Anfang der 1990er gehörte Maserati zu De Thomaso oder Fiat, daher eigentlich keine Verbindung zu PSA. Maserati war da schwer in der Bitubro-Phase, als V6 bis 2,8 Liter, als V8 mit 3,2 Litern Hubraum. Der V8 wird kaum in den XM gepaßt haben... Und einen 3,0 V6 gab es bei PSA, wenn auch mit weniger Leistung.
