Wer kennt eine Lösung für den Lehlercode P1166 ?
Ist kein allgemeiner OBD-Code sondern herstellerspezifisch. Da hilft nur auslesen lassen. Kann so einiges sein:
Engine ECU
Fault code P1166
After sales description of the fault code High pressure fuel regulation : Measured rail pressure higher than the maximum pressure
Description of the diagnostics Measured rail pressure higher than the maximum pressure (for 5 seconds)
Conditions of activation of the diagnostics Consult the associated contexts for the Pcode forwarding conditions
Conditions of disappearance of the fault Driving for 5 minutes
Down-grade modes if fault present Switching off of the engine
Irreversible cutting of the cruise control
Deactivation of automatic mode for the electronic parking brake
Deactivation of the speed limiter
Switching on of the warning light and/or warning message Warning lamp MIL
Main customer complaints likely Lack of power
Jerking/stalling
Suspect areas Electrical harness
Wiring
High pressure fuel pump
Fuel flow regulator
Low pressure fuel circuit
Fuel filter
Engine management ECU
Fuel high pressure sensor
Quelle: http://c4owners.org/plugins/forum/forum_viewtopic.php?60304
